In Windchill: Under tab Structure, Attributes, Document Attributes I need to change Type: from "Information Bulletin" to "Document"
How can this be accomplished?
Need an object type change utility. We had one at my last company.
I believe that PTC still only provides a tool that outputs the SQL to change directly in the database.
How to change the Type for an existing object in Windchill PDMLink
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS7287
