In the query builder report, how to get an assigne name (in a role) from a workflow?
For example, I want to list the Project leaders from each workflow, linked, of course, to a documet.
Daniel,
take a look at this article I wrote Resource for reporting
There are many query builder report already done.
Maybe you can find something useful for you.
Marco
Daniel,
Marco
Hello Marco
After some time, trying to find a wat in the link that you sent to me, I found a tip that guided me to my answer.
Daniel,
even if redundant, maybe you can add exact answer for other users in this discussion.
Great Marcos, You're right.
If someone is trying to do same, follow these instructions:
1. Selecting in "From" according picture:
Note: In my case the target workflow is "Desenvolvimento Alteração Produto". Select the yours.
2. In "Join":
3. Now in "Select" you need to set your choice, and remind to use "User.Full Name" and "Work Item.Role" to show the responsible for a task in the workflow:
4. Another good tip is, in "Criteria" create a condition according bellow to show only open tasks:
It is all!
