Increase the character length for add participant tab.When we are searching in add participant tab it is maximum taking 200 character which is a 00TB functionality as per PTC and cannot be changes. We are in Windchill 11.1.
You need to search on more than 200 characters????
Good point @BenLoosli ,
I can not imagine that a user's name could be longer then 200 characters.
PetrH
My guess is a semicolon separated list of usernames.
{username1};{username2};{username3};...
The workaround for that scenario is to dump the full string of usernames in Notepad++ and split the list so that each search string is less than 200 characters. Then search one line of usernames at a time.
Seems a lot easier than trying to change Windchill to accept longer search strings.
FYI: That is also what the knowledge base article recommends.
You also run into a limit of how many names can be returned by the search operation.
Good point, but we can expand the participant search results.
https://www.ptc.com/en/support/article/CS149582
The more results, the slower the UI will run. So need to use some common sense on expanding this one. I usually double it from 100 to 200.
You can also enable automatic wildcards. This makes searching for participants much easier.
xconfmanager -s com.ptc.netmarkets.user.principalWildcardSearch=true -t codebase\wt.properties -p
Hi @AD_10463958
generally you could try to find the jsp page wizard and rewrite a onpaste or onkepress script with higher value.
PetrH
