Dear Users,
I am trying to write a EPMSuggestBox which will shown all EPMDocument when the Global Atribute DOCUMENT_TYPE= 'SAAF' . I've tried the below search using where clause , but still the text box shows other EPM Documents where DOCUMENT_TYPE<> 'SAAF' .
Can you please share your ideas.
Regards
Sriram Rammohan
protected void setTaskParams(Task paramTask) throws WTException, IOException { WTUser localWTUser = (WTUser) SessionHelper.getPrincipal(); WTProperties localWTProperties = WTProperties.getLocalProperties(); String str = localWTProperties.getProperty("wt.federation.ie.VMName"); paramTask.setUsername(localWTUser.getAuthenticationName()); paramTask.addParam("object_type", "wt.epm.EPMDocument|com.xxx.DefaultEPMDocument"); paramTask.addParam("search_type", "wt.epm.EPMDocument|com.xxx.DefaultEPMDocument"); paramTask.addParam("where", "(name='" + this.search_term.trim() + "')&(checkoutInfo.state!='wrk')&(latestIteration='1')"); /*paramTask.addParam("where", "(DOCUMENT_TYPE='SAAF')"); paramTask.addParam("where", "('IBA|DOCUMENT_TYPE'='SAAF')"); paramTask.addParam("where", "IBA|DOCUMENT_TYPE=SAAF"); paramTask.addParam("where", "IBA|DOCUMENT_TYPE='SAAF'"); */ paramTask.addParam("where", "(DOCUMENT_TYPE='SAAF')"); paramTask.addParam("where", "(IBA|DOCUMENT_TYPE='SAAF')"); paramTask.addParam("dca_attribute", "name"); paramTask.addParam("dca_attribute", "number"); paramTask.addParam("dca_attribute", "type"); if (this.excludeSubTypes != null) paramTask.addParam("excludeSubTypes", this.excludeSubTypes); paramTask.addParam("group_out", "output"); paramTask.addProcessor(str); paramTask.addParam("supporting-adapter", str); }
