Hello guys, is there a way to add multiple existing parts when modifying a BOM?
Instead of adding one per one, it is allowed when creating new parts "Create multiple parts"
But not when already created
Could you please help?
Thanks!
Use copy/paste.
You could search all the parts using ";" separator or copy form a folder.
Use copy/paste.
I just tried in PDML 11.2 and you can select multiple parts while insert existing. Use shift + select
What is your usecase exactly ?
