Inserting Versions
wfalco
Inserting Versions
All,
I have a situation where we had two drawings releases, A & B. The changes were done concurrently. However, someone asked if another change can be added to A. Well, I pulled A up "as stored". No problem. Can get a print and make someone happy. However...ideally that version should be slipped into the iteration history - if anyone really cared - and they may not. As long as I have the print of the change, I can turn a blind eye. But I was wondering if it would be possible to slip that the A+ version after A and before B? This may involve some parts and assemblies? I have some tricky things I may be able to get away with. But...if there is a technique, please share?
Wayne
Creo 4.0
WC
 11.0 M030-CPS13
MikeLockwood
22-Sapphire I
(To:wfalco)
Have had to do this at times over the years.
Very messy if you have WTParts and change management, and integration w/other systems, but assuming just CAD data management:
- Preserve files for Rev B (export from workspace)
- Delete Rev B
- Bring original Rev A into workspace
- Import modified Rev A to workspace, select Add as Modified to any that should have changed and ReUse existing for any that should not change.
- Check in modified Rev A
- Revise to Rev B in workspace
- Import preserved Rev B
- Check in Rev B
6 REPLIES 6
MikeLockwood
22-Sapphire I
(To:wfalco)
- Delete Rev B
- Check in Rev B
An additional step after you check-in Rev B again.
Revise the rev B with the same added change done to the rev A.
If you don't do this then the rev B will not match what came from rev A.
As for version history, it will be a bit convoluted, but explainable,
wfalco
(To:BenLoosli)
Hmm. Thank you. I have not decided to pull the trigger yet. Appreciate the input.
wfalco
(To:MikeLockwood)
I've yet to try. But this looks good. I am debating if I will attempt or wait till I have to? But thanks for the response!
joe_morton
(To:wfalco)
If it's just a drawing change, you can do these steps:
Check out the A.X version. Windchill by default will give you an overrideable conflict preventing you from checking out a version that is not the latest.
Make the changes in A.X and then check in
Your changes will be checked in as A.X+1 (which doesn't affect revision B at all)
This obviously gets much more complicated if your changes also affect models, WTParts, etc., but the same logic applies to other items in Windchill
wfalco
(To:joe_morton)
Now this is along the lines of something I would do off the cuff. Good stuff. Thanks for contributing. I may wait till the drawings are officially released till I muck around. If I even do. This is all good logistically speaking. But may just be a preparation for what likely will never be something ever revisited?
