Hi am,
I'm trying to install PDMLink 9.1 M040 on a Windows Server 2008 x64 machine. I have Oracle 11.1.0.7 installed. (using the PTC recut Win Server 2008 x64 CD: MED-2200B-CD-108_2009000.zip)
The PTC Solution Installer (PSI) errors out on me during the OCU stage. The PSI spits out:
Installation is Aborting.
4/12/10 12:21:16 PM: The following logs contain information that may be useful for diagnosing installation problems.
4/12/10 12:21:16 PM: Please include them in your support requests.
4/12/10 12:21:16 PM: D:\PTC\PDMLink\ocu\installer\logs\OCU_PtcInstall.log
4/12/10 12:21:16 PM: D:\PTC\PDMLink\ocu\installer\logs\OCU_InstallLog.xml
Looking at the logs doesn't show anything of interest, merely a repeat of the PSI error message.
Am I doing something wrong?
Hi Warren,
Could you also attach the PSI logs and "D:\PTC\sharedComponents\Oracle\cfgtoollogs\dbca\wind\wind5.log “
Am 100 % confident that this is a access issue.
Can you once verify the same with admin access, if using the same machine?
Also can you verify if you are able to access the database and the schema created? I believe you are also installing the database and creating the user in the same instance.
Mayur
