Anyone have the simple solution to this error? I am running PSI as root and have full rights to the staging directory. As soon as I click on begin install, I get the error about javasdk can't continue and it stops right there. The interesting thing is that I installed Windchill 11 on another clone of the server without getting this error. From what I read, it could be a rights issue somewhere, but I am running this as root. Anyone have any ideas on what to look for? Thanks in advance!
Hi Mitch,
Can you check if the below article helps. If not, can you share the logs.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS241829
Bhushan
Are you by chance installing on a workstation for test, not a server? I always play with Windchill a lot at home - using a personal laptop
I got a new laptop with Windows 10 on it recently and found that you cannot run the installer using Windows 10 yet - had to set up Win 7 professional. All installed ok.
Actually, since that time I "punted" and found my M010 files and got past that point. DK if my javasdk files were corrupted on not. Thanks anyways to all.
Hi Mitch,
are you fixed this problem ?, I have the same bugs when I try to install windchill in linux Red Hat with PSI Bundle CPS06.
I fixed it by installing Windchill 11 M010.
Thank you Mitch, but it's not work for me.
Hi all,
finnally my problem is in the name of folders Medias, I have space in the name, my problem is fixed when I have delete all space and specials caracteres in folders name.
Thank you
regards
