Instances are getting modified again
Dmi3U
Hi All!
Upgraded to Creo 3.0 m050 and Windchill 10.2 m030 a couple of weeks ago. Now when I add an instance to the family table it insists: "To save this generic, the entire family table must be updated". I do the same actions in Creo2.0 m070 (and WC 10.2 m030) with the same config options and it is modifying only the generic and a new instance. Anybody was able to solve this? I have a call opened with PTC, no resolution so far.
Any help is appreciated!
Thank you,
Dmitry
This article might cover it: CS43130
Did they change the internal format again? Those without maintenance feel left out.
TomU
(To:dschenken)
If the family table was already re-verified in Creo 2, then it should not be happening again simply by going to Creo 3.
Relevant Section:
dschenken
(To:TomU)
Thanks. No wonder the bean-counter sysadmins -hate- family tables. A bump required for the otherwise untouched instances? Even the ones that understand why must tire of explaining to their management why extra work is required.
