Hi All!
Upgraded to Creo 3.0 m050 and Windchill 10.2 m030 a couple of weeks ago. Now when I add an instance to the family table it insists: "To save this generic, the entire family table must be updated". I do the same actions in Creo2.0 m070 (and WC 10.2 m030) with the same config options and it is modifying only the generic and a new instance. Anybody was able to solve this? I have a call opened with PTC, no resolution so far.
Any help is appreciated!
Thank you,
Dmitry
Did they change the internal format again? Those without maintenance feel left out.
If the family table was already re-verified in Creo 2, then it should not be happening again simply by going to Creo 3.
Relevant Section:
Thanks. No wonder the bean-counter sysadmins -hate- family tables. A bump required for the otherwise untouched instances? Even the ones that understand why must tire of explaining to their management why extra work is required.
