I have installed Creo Parametric 11.0.3.0 and Creo Parametric 10.0.7.0 along with Windchill Workgroup Manager (WWGM) 13.0.1.1. I am looking to integrate WWGM with Creo Parametric 11.0.3.0 and register it with a new server to enable seamless interaction and functionality.
Please assist me in:
This issue is blocking my daily activities, and I would appreciate prompt assistance in resolving it.
Thank you for your support.
Regards, Vinit Kumar
Creo Parametric does not work with WWGM. It has native connections inside of it. WWGM is not needed for Creo Parametric to connect to Windchill.
Hello @VB_12246828
As @avillanueva mentioned, Creo Parametric in its recent releases no longer needs Workgroup Manager, it connects directly with Windchill PLM via "Direct Link", you only have to check the compatibility between Creo and Windchill in Software Matrices/Release Advisor.
You still need to install WWGM for Solidworks and AutoCAD, again you need to confirm that your stack are compatible with each other via Software Matrices/Release Advisor.
Link to Release Advisor
Hi @VB_12246828,
Anurag
Hi
We discovered some time back, that during installation of WWGM we need to add several or all versions of SolidWorks and AutoCAD to the installation, otherwise we couldn't connect.
Don't know why, but it solved the issue.
Be sure to check the software compatibility matrix for WC WGM to make sure you are connecting supported versions of CAD apps to WGM
