Intralink 10.2 CAD-Worker
Robert-Altman
If using Windchill/Intralink 10.2 (not pdmlink) can a "CAD Worker" be configured to create exported STEP during the release workflow?
I don't have access to a Pro/Intralink now to verify, but   this is possible in Windchill where you can create a publishing rule to generate STEP from worker. if you are using promotion object for release, there is a preference that push a publishing right after Promotion creation. If you are using any other workflow, you can trigger a publishing from workflow too.
I believe this is possible in Pro/Intralink as it uses same codebase, just by removing support for enterprise part. More over  PTC has Pro/Intralink in "applies to" of this CS - https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS81396.
So it is a yes
Binesh Kumar
So it is a yes
Binesh Kumar
Binesh, Once again I can not thank you enough for your help.
