In Intralink 3.4, to log out from one's current User account and then log in as a different User, it was easy: just do a "ReLogin" from the Intralink pulldown menu in either the Commonspace or Workspacewindow.
In Intralink 9.1, I don't see such a cut and dried menu choice for logging in as as different User.
Even if I exit Internet Explorer..., then relaunch Internet Explorer..., then return to my Intralink 9.1 URL..., sometimes I am presented with a Login dialog box but more frequently I am instantly logged in under the previous User account login. Same thing even if I open a second Internet Explorer window.
FYI: I have need to do this because for my daily design work I loginunder anormal User account, but when I need to do adminstrative tasks in Intralink then I login under a different User account with Adminstrator privileges.
Does anyone have a tried and true method of logging into Intralink 9.1 as a different User?
TIA!
Thanks to all those who replied. PCT/User to the rescue yet again!
Of the solutions offered I have tried thus far, here is the worked-every-time remedy from MF at ATK:
"In Internet Explorer go to File>New Session"
Each time I took that approach, I was presented with a fresh Intralink 9.1 login dialog box in which I could login as a different user. Lovely!
My thanks and a tip o' the that to MF at ATK!
Generally speaking, Ben's methodology is preferred if alternate browsers are supported by IT. The inherent advantage is that it is much easier to remember who you are logged in as, particularly in R9.1 where the user's name is only presented on the home screen (ootb, anyway).
I finally had time to edit the shortcut that launches IE to this...
"C:\Program Files (x86)\Internet Explorer\iexplore.exe" -noframemerging
...and that works great, too. The disabling of the Framer Merging is definitely the solution.
Disabling through the Windows registry also sounds like a sure-fire fix but I'm settling for this shortcut remedy.
Thanks to all who replied!
