I want to upgrade my windchill server (9.1) to windchill (10.2) : ok for this
But my problem is Inventor 2011 : not supported in 10.2, but not incmpatible.
Have you already test to connect Windchill 10.2 WokgroupManager and Inventor 2011.
Thanks in advance.
Vincent
Inventor 2011 is not supported with WC 10.2. You can upgrade your Inventor to 2012/3/4, check the software matrix here http://support.ptc.com/WCMS/files/157177/en/Windchill102M030CADIntegrationMatrix_121415.pdf
Shashi
Shashi
I had already seen that Inventor 2011 will was not supported with Windchill 10.2 when I wrote my first message, but my end-customer was "scared" to migrate in Inventor and Windchill together.
I hoped to find a way to make them communicate between us with an other way
Finally, we realized both migration at the same time ..... and itworks perfectly
Vincent
