Is anyone using PDMLink in association with an architectural/civil engineering group that does not use Creole and very little solid modeling?
jhamilton
I am from a predominately mechanical engineering back ground, but recently joined another organization that is predominately architectural/civil/electrical and process engineering. They also do not have any Creole but purchased PDMlink because it was recommended to them. While PDMlink can do the job, it seems like a massive overkill and a tool not designed for the task it was intended to be used on. Is anyone else doing this successfully in such an environment?
0 REPLIES 0
