Is it possible to print a list of drawings from a Change Task? Right now, the only way I know how to is open each individually.
You can copy drawings from the affected/resultant objects table. This will add the items to clipboard. Use print in creo view option to print all the selected objects in clipboard. http://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=InteropClipboardTableRef&action=show
Thank you
Binesh Kumar
