Is it possible to set "Add to workspace" filter based on specific criteria
Newbie
Consider criteria where objects are searched by Latest then "add to workspace" is performed and Windchill should use filter "Latest"
When "add to workspace" criteria is "Production" then Windchill should use filter "As Stored".
PDMlink does not store / no option to store these settings.
For example
1)Add to workspace
2)Edit filter
3) Configuration Spec changes, Let say in Step #1 search  criteria is “Latest” then the Configuration Spec should be Latest search and if Step #1 is Search for Production file then the Configuration Spec should be “As Stored”
Tags (1)
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________ Check out the Windchill Tips Board! We're talking about Whirlpool's use of digital twin, augmented reality, and data-driven design!
The NAVIGATE WORKING GROUP is here! Come innovate with PTC!
Sign up for a Working Group
