Is there a way to Uninstall Windchill Web Parts for Sharepoint ?
hbhattalwar-2
We wanted to uninstall Windchill Web Parts for Sharepoint
1. Is there a way to uninstall it ? If yes,
2. Any Document which will help?
Any clue or guidance will be highly appreciated! Thanks!
Regards
Harshal
On the sharepoint server, you should be able to uninstall Web Parts through the Windows Control Panel. On the Windchill server, you can undeploy the Web Service, though that won't remove Windchill Web Parts from the Windchill version information.
if you are trying and if upgrade manager ever gets stuck verify supported upgrade path, you scan set the assembly id for webparts in
com.ptc.win​dchill.upgrade.skippedAssemblyIds (wt.properties )
Thank you
Binesh Kumar
Barry Wehmiller
Hi Binesh/Chris,
Thanks for the reply!
Basically we wanted to perform upgrade activity and it dint creep about Web parts on Source system.
So, we are all set! Thanks again!
Regards
Harshal
