Every time a new user logs into a machine with Autocad and the WGM installed, they must first register our Windchill server and register the Autocad application. Is there a way to automate this, for instance a script file that will do this automatically, that can be run the first time a user runs the application? Even if the automation is standalone, (ie its own shortcut that must be run manually by each user) it would be beneficial to administrators to have.
