Is there a way to download otb workflow templates for windchill 12.1
RP_10964853
6-Contributor
Version: Windchill 12.1
Use Case: Load OTB workflow templates.
Description:
User needs to load otb workflow templates since he has loaded over the otb ones. Is this possible?
Do you mean the user has modified the OOTB ones? Is there not a iteration history that you can go back to? Yes, there should be a way. Looking for solution but likely its a LoadFromFile method.
