Is there an opt-in/opt-out functionality (to opt-out of newer functionalities and to get only bug fixes) when installing Windchill 10.2 or 11 ?
If you are upgrading, then there are no options to suppress the enhancements from showing up.
If you are doing a maintenance update, you can use the property Release.optIn to control the "newly introduced features"
Thanks Binesh , this is the property I was looking for.
Have a great day,
-Bilal
