Is there any way to add comments to a previously checked in iteration?
mdebower
18-Opal
Windchill 10.1 m040
RandyJones
20-Turquoise
(To:mdebower)
Marc DeBower wrote:
Windchill 10.1 m040
This is stored in the noteiterationinfo field in the wtdocument table. Editing it would work very similar to what is described here:
EDIT A COMMENT IN THE VERSION HISTORY FILE. - PTC Community
RandyJones
20-Turquoise
(To:mdebower)
Marc DeBower wrote:
Windchill 10.1 m040
Thanks Randy.
Crikey!  So there is a way for an admin to do so, but not a "normal" user with the correct permissions.   Oh well.
You really shouldn't have to be a Software Engineer to administer the system.
-marc
BenLoosli
23-Emerald II
(To:mdebower)
I would not want all users to have rights to edit that data.
Control rights by ACL to allow admins or others to execute a script that would edit a comment.
Ben, neither would I.   It should be an ACL to give the correct permission to change the comment.  On the other hand, I shouldn't have to run a SQL script to change it either.
