Is there any way to get the history of standard time of operation from Process plan ?
- can we get the history of standard time of operation when it changed.
Hi @K_Patil
If the time is changed, then the operation has to be iterated so get all information from all iterations and control the attribute value.
You can do it by a Report Management.
or just go to previous operation iteration and check the attribute value.
PetrH
Hi @K_Patil
PetrH
