Isuue about resourse allocation
vijaykamdi
Version: Windchill 11.1
Use Case: MPM link during add machines and work center i am facing issue with resourse allocation in progress
Description:
MPM link during add machines and work center i am facing issue with resourse allocation in progress,not immidiate to add.
HelesicPetr
(To:vijaykamdi)
Hi @vijaykamdi
It seams that there is some performance issue. It could be also a different reason .
It needs to diagnose this behavior, because there are many reasons why it is not added to the operation.
You should contact Windchill admin to check logs, if there are not any interesting information, set the log level to debug or trace and so on.
PetrH
Hello @vijaykamdi
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
