It is possible to export all documents of an EBOM (cad drawings, pdf) and also all drawings generate
AR
Version: Windchill 12.0
Use Case: It is possible to export all documents of an EBOM (cad drawings, pdf) and also all drawings generated by the publisher that are inside Representations/Annotations!! How can it be done?
Description:
How can it be done?
HelesicPetr
22-Sapphire I
(To:AR)
Hello @AR
The OOTB function is the Package process
You can collect all data you need. And the final zip file will contains all data.
Help Center - Create Package
PetrH
