JMeter + Windchill : Multi User Login
Sriram_Rammohan
Hello All,
Can you help in sharing your inputs in setting up Jmeter with multiple users accounts , hitting the System to generate load on the System. I was able to do the same with multiple sessions for a single user , but finding it tricky to do it with 'n' users,
Example :
UName1,Pwd1
UName2,Pwd2
UName3,Pwd3
In this case i wanted all the 3 users credentials to be used in Jmeter to create a real-time scenario. I tried to create a csv file and tag it under the CSV Data Config but it doesn't work. Any ideas or improvements are welcomed.
Sriram Rammohan
0 REPLIES 0
