Knowledge base in Windchill
ysinitsin
Not sure that is possible, but... I want to build a Knowledge base in my enterprise. Is there any solution to make some thing like this using Windchill?
There is a discussion and power point that might be the model you are looking for...
"Windchill Configuration Change Management (2011 PlanetPTC Follow Up)" by Chris Russell
If this link doesn't work then use Search
http://communities.ptc.com/message/164451#164451
Thanks for answer! Will try to understand.
I looked to problem from another point and now, I think, a private group in PTC Community can be not bad solution.
