[LDAP: error code 49 - Invalid Credentials]
Re: [LDAP: error code 49 - Invalid Credentials]
in addition with jndi you must respect this exact process :
your original map credential file is located at windchill\codebase\WEB-INF\mapCredentials.txt and looks like this if using an enterprise ldap :
mapcredentials.admin.adapters=net.<yourdomain>.Ldap^cn\=<DsAccount>r^encrypted.net.<yourdomain>.Ldap.cn\=<DsAccount>r;net.<yourdomain>.<yourserver>.ldap-pending^cn\=<DsAccount>^encrypted.net.<yourdomain>.<yourserver>.ldap-pending.cn\=<DsAccount>;net.<yourdomain>.EnterpriseLdap^<youraccount>^encrypted.net.<yourdomain>.EnterpriseLdap.<youraccount>
mapcredentials.nonprivileged.adapters=
The new map credential will erase the old one, using the shell, ldap info per ldap info, ie : ldap, pending then after ldap and ending with enterprise ldap.
caution : input the "-" with your keyboard rather than copy paste in the shell.   the "<>" must be replaced with "your data".
open a windchill shell and type :
xconfmanager -t codebase/WEB/mapCredentials.txt -s "mapcredentials.admin.adapters=net.<yourdomain>.EnterpriseLdap^CN=<youraccount>,OU=<depending on your enterprise ldap orgs>,OU=< same specific> -,DC=<yourdomaindc>,DC=net^<yourpassword>"
hit enter, the shell will display :
Default product root=[...]Windchill\bin\.. java -jar "[...]Windchill\bin\..\codebase\WEB-INF\lib\install.jar" -r "[...]Windchill\bin\.." -t codebase/WEB/mapCredentials.txt -s "mapcredentials.admin.adapters=net.yourdomain.EnterpriseLdap^CN=<youraccount>,OU=<depending on your enterprise ldap orgs>,OU=< same specific> -,DC=<yourdomain dc>,DC=net^<yourpassword>"
then type
xconfmanager -t codebase/WEB-INF/mapCredentials.txt --add "mapcredentials.admin.adapters=net.<yourdomain>.Ldap^cn=<DsAccount>^<DsPassword>"
Default product root=[...]Windchill\bin\.. java -jar "[...]Windchill\bin\..\codebase\WEB-INF\lib\install.jar" -r "[...]Windchill\bin\.." -t codebase/WEB-INF/mapCredentials.txt --add "mapcredentials.admin.adapters=net.yourdomain.Ldap^cn=<DsAccount>^<DsPassword>"
then type
xconfmanager -t codebase/WEB-INF/mapCredentials.txt --add "mapcredentials.admin.adapters=net.<yourdomain>.<yourserver>.ldap-pending^cn=<DsAccount>^<DsPassword>"
Default product root=[...]Windchill\bin\.. java -jar "[...]Windchill\bin\..\codebase\WEB-INF\lib\install.jar" -r "[...]Windchill\bin\.." -t codebase/WEB-INF/mapCredentials.txt --add "mapcredentials.admin.adapters=net.<yourdomain>.<yourserver>.ldap-pending^cn=<DsAccount>^<DsPassword>"
then type
xconfmanager -p
then restart apache an windchill.
