LDAP export error
NJ_11253659
LDAP export error
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS22
Getting the below error when trying ldap export or backup from windchill directory server :
You have provided options for scheduling this operation as a task but options provided for connecting to the server's tasks backend resulted in the following error: 'Connect Error'
Here is an article that details steps: https://www.ptc.com/en/support/article/CS36256
You can always post the command you were trying here but please leave out details like hostname, username and password. I assuming you checked that those were accurate. Note that WindchillDS is based on OpenDJ. PTC has retired this so anything you find online that is for OpenDJ is almost an exact match.
rleir
(To:avillanueva)
The command I tried is :
wthome\WindchillDS\server\bat\export-ldif.bat -n userRoot -l C:\Users\Administrator\Documents\ldapexport.ldif -a -h hostname -p 4444 -D cn=Manager -w ******* -X
I got the same error when I tried to export from the PTC Windchill directory server control Panel-> Directory data-> export LDIF
This was mine I always use. There is also the Control Panel to do exports:
export-ldif --backendID userRoot --bindDN cn=Manager --bindPassword <Pw> --appendToLDIF --ldifFile sourceLdap.ldif
