LDAP export
Newbie
LDAP export
I'm trying make an export of the ldap by using the export command.
When i write it in the cmd window it works fine. But when i try to do a bat-file it just don't work.
What do i do wrong or is there any better way to backup the ldap database?
@echo on
call R:\usr\sbin\lde>export -f R:\usr\var\lde\PTCLdap\PTCLdap_lde.conf backup.ldif
@echo on
/Magnus
6 REPLIES 6
RE: LDAP export
RE: LDAP export
On a related note, I need to just export the people branch. Can that be done with the export command?
Wes
(559) 292-1981 x3438
559.940.3991
(Sent from Blackberry...)
RE: LDAP export
RE: LDAP export
Check the Upgrade Documentation for 7.0
Windchill comes with wt.* utilities for exporting certain sub-trees from the
ldap.
Regards
- Sayee
Accenture.
RE: LDAP export
Make sure that you increase the SizeLimit setting in PTCLdap_lde.conf to ensure you get all records.
Andy Bruce
RE: LDAP export
Rudi,
I usually set to export without the -o option, then copy R:\usr\var\lde\PTCLdap_database\root.ldif to a different location on completion. It seems to work fine every time.
Andy Bruce
PTC GS
