Any idea, if there is any API we can link a CAD Document to other CAD document via reference.
Windchill 12.0 version.
Basically the idea here is , For a Given document we will have some references from the other CAD document. Need to know if we can link via code as reference in related objects.
It will be helpful if anyone worked on such use cases or can share some insights.
Thanks in advance
Hello @JM_10276355
Your needs covers a Configuration Reference Links
the description how to use the Configuration Links is in a Windchill Help Installing the Configurable Links Example
This is customization where you need to create own wizard and tables to show the Configuration Links.
The help describes just example how to do so.
Hope this can help.
PetrH
Hello @JM_10276355
Hope this can help.
PetrH
