Hi Guys,
currently I´m trying to understand the database schema behind Windchill PDMLink.
My aim is to get all parts of an assembly, with all the attached information.
Now I have looked over some tables and foudn the links beetween them. But now I´m stuck!
How can I link the information from the EPMDocument (EPMDocumentMaster, ...) with the WTPart (WTPartMaster, ...) tables?
WTPartMasterKey and EPMDocumentMasterKey both have the field WTKey, but the have different contents.
I´m using Windchill PDMLink 9.1.
Thanks in advance!
Ben
Hi Ben,
look at this document I wrote http://communities.ptc.com/docs/DOC-6348
It's very long, but in the Tips and tricks section you can find an answer.
Hi Ben,
Hi Marco,
thanks, that´s awesome!
Way more than I expected.
