Load WTDocument without IBA's
Newbie
Hi All,
I am trying to load WTDocument object without IBA's on Windhcill PDMLink 8.0 M040. I am using OOTB windchill loader. The IBA's do not have any default values assigned. When I loads the object using OOTB loader, an entry is made to the StringValue table, which I want to avoid as we r not using any default values. When I tried to create the object using GUI, it works as per the expectation and object is created without a single entry in StringValue table.
As per my knowledge, an IBA will not be persisted into DB unless we specify the IBA's in data file using wt.iba.value.LoadValue method. We didn't used this method at all. I went through the class files, there is no direct call to this method.
Kindly reply if u have any suggestions on this. Thanks.
Yogesh
