Load from File- New WT
Amirtharaj_K
Hi Guys,
I am looking for WT Parts that will be created and loaded from Excel.
This is one I tested individually, and it works.
[ If i add this it's not work: <csvlifecycle>vtc</csvlifecycle> <!-- Added: Life Cycle Template --> | <csvcontext>Testing Purpose</csvcontext> <!-- Added: Context --> | <csvlocation>/Testing Purpose/2. WT Parts</csvlocation> <!-- Added: Location -->]
<?xml version="1.0" ?><!DOCTYPE NmLoader SYSTEM "standardX20.dtd">
<NmLoader>
<csvBeginCreateOrUpdateWTPart handler="wt.part.LoadPart.beginCreateOrUpdateWTPart" >
<csvpartName>Demo_load_part</csvpartName>
<csvpartNumber>0000000101</csvpartNumber>
<csvtype>separable</csvtype>
<csvgenericType></csvgenericType>
<csvcollapsible></csvcollapsible>
<csvlogicbasePath></csvlogicbasePath>
<csvsource>make</csvsource>
<csvfolder>/Default</csvfolder>
<csvview></csvview>
<csvvariation1></csvvariation1>
<csvvariation2></csvvariation2>
<csvteamTemplate></csvteamTemplate>
<csvlifecyclestate></csvlifecyclestate>
<csvtypedef></csvtypedef>
<csvclassToUpdate></csvclassToUpdate>
<csvorganizationName></csvorganizationName>
<csvorganizationID></csvorganizationID>
<csvsecurityLabels></csvsecurityLabels>
</csvBeginCreateOrUpdateWTPart>
<csvEndCreateOrUpdateWTPart handler="wt.part.LoadPart.endCreateOrUpdateWTPart" >
<csvparentContainerPath></csvparentContainerPath>
</csvEndCreateOrUpdateWTPart>
</NmLoader>
I want bulk load from excel sheet, i want know, how we can create this in excel too.
Amir
8 REPLIES 8
If you are just loading parts from a spreadsheet, you are better off using this method:
https://support.ptc.com/help/wnc/r12.0.2.0/en/#page/Windchill_Help_Center%2FImExImportAbout.html%23
Much easier. This is done via the normal UI.
Hi @Amirtharaj_K
A simple way to get the correct excel format is to export one part from Windchill GUI. From Part Detail page select Action - Export importable spreadsheet
Then you can modify the file to fit with your new parts. You import spreadsheet from Products Details page - Action - Import importable spreadsheet.
If you like to use loadFRomFile from Windchill shell you can find samples of file
[Windchill_Home]/loadFiles
[Windchill_Home]/loadXMLFiles
see detail : Article - CS138169 - [Knowledge Hub] Windchill PLM - LoadFromFile Utility (ptc.com)
Johannes
Fadel
(To:Amirtharaj_K)
@Amirtharaj_K  , glad to hear from you again , take any part in your windchill , and export it as excel spreadsheet, use the exported file as template .
The export action is  on the info page of part , the import is on folder table view
Fede
Amirtharaj_K
(To:Fadel)
Thanks for the reply guys and apologize for the delay in response.
How we can use the loader to do this, and how we can add the attribute's name and value here?
Article - CS172839
What is the CSV file format for converting to XML and loading WTPart in Windchill PDMLink
Aj
Fadel
(To:Amirtharaj_K)
@Amirtharaj_K  chcek https://www.ptc.com/en/support/article/CS195189 for loader to update iba value .
for the csv , check your windchill installation folder for a file called csvmap.txt , it has csv syntax for all OOTB loader
Fede
Amirtharaj_K
(To:Fadel)
Thanks for the reply, Mr. Fadel. I apologize for the delay in responding.
I tried this one, but only one data can be uploaded at a time. How can we upload multiple data?
Thanks in Advance,
Aj
Fadel
(To:Amirtharaj_K)
you can use one xml to update multiples objects, there is no constraint to sue one file per part to update
Fede
Look at Windchill/loadFiles/csvmapfile.txt. It should have the column headers you are looking for in your CSV file
https://support.ptc.com/help/wnc/r12.1.1.0/en/index.html#page/Windchill_Help_Center/WCDataLoadGuide/WCDataLoad_CreateMethodCustomLoading.html
