LoadFromFile CSV file format for multiple documents
FS_10200711
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.1.2
what is the format for the CSV file to use with LoadFromFile when I have 10 or more documents to load. I can load a single document ok but not when adding another document to the same csv file. file will convert to XML ok but not load?? CSV & XML files attached. MS log as well
You can follow the step outline in this tech support article. Additionally you can also refer this article.
Hope this helps.
regards
~Syed
No files were attached.
