Version: Windchill 12.0
Use Case: Loader failed during windchill PDMlink 12 installation.
Description:
the installation completed almost 63% where it shows an error "Loader Failed".
the method server logs shows "license error: capability response is null. if valid license is not acquired, method server will shut down in 330 minutes."
I've already installed Oracle (software only), DS (from version 11).
when i ran the PSI, i had chosen option "configure license later".
i am installing windchill to learn customization. i don't have any license. kindly suggest.
Br,
Sandeep C.
The error that method server will shut down is expected. This error is a red herring, you can ignore that as method server will always shut down after 330 minutes when there is no license. Once licenses are applied this error will go away. Licensing or lack thereof will not impact installation or loading.
