Loading BOM using 'Import from Spread Sheet' UI - Setting IBAs
RajuPulavarthi
Is it possible to set or update the IBAs(String) associated with the Part Usage Link (WTPartUsageLink) using the 'Import from Spreadsheet' functionality? If so, can you please let me know the format to be used in the spread sheet provided by PTC(<windchill home=">/codebase/examples/xls/bom-import-template.xls)? We are on Windchill version 10.1.
Raju
Raju Pulavarthi
-<blocked::<a style="COLOR:" blue;=" text-decoration:=" underline&quot;=" target="_BLANK" href="mailto:-">">mailto:->
0 REPLIES 0
