Currently, the system’s Audit Report function records user login information based on user login sessions. Since the default session duration is 30 minutes, any re-login within this 30-minute window (even if on a different device or browser) will not be recorded in the Audit. • There is currently no configuration option to record every single login attempt in the Audit. • To improve this feature, it would be helpful if each login attempt could be recorded or if there could be an option for customers to choose between recording every login attempt or ignoring re-logins within a 30-minute window.
You can bring all your ideas here - "Windchill Ideas": https://community.ptc.com/t5/Windchill-Ideas/idb-p/WindchillIdeas
Hi @VL_10298701
Do you know that there is a record that shows users IP address if a user accesses to a context?
so it is recorded that user access from different place if any action in the system is done as a call to get information from any place
PetrH
