Looking for a Part Where Used for current Version only
Aquamarine
I'm looking to add a Where Used report that only returns items if the parent part is the current version.
WC 11, M020
I see there is some help here but report creating is not in my wheelhouse 🙂
https://community.ptc.com/t5/Windchill-Questions/Resource-for-reporting/m-p/448738
Attached is a version of the report but for EPM Docu's
Tags (2)
8 REPLIES 8
Re: Looking for a Part Where Used for current Version only
Hi
If you mean latest version when you say "current version", i have attached an exemple edited from CS210416
Not quite. It seems to return where it is structured (I would need to at the Version into the report table to see). If I revise an assembly and drop the part I am searching for it still shows in the report.
In Vincent's xml file there is not a sub-select, that is the only way to achieve the very latest version.
Marco
Not my skill set. Anyone know how to do that?
Exemple in CS1171
Attached updated version
Thanks Vincent. Having trouble loading it.
We are on 11, M020
I have re-exported as zip ( 11 M030 )
Thanks.
