Greetings,
Wondering if it is possible to control who can see different BOM Views?
We can create the new View in a location that has limited access, but would that restrict seeing the view in the part history tab. Would the restricted location also prevent users from revising the wrong view.
Hi Casey,
I would like to ask if you guys are maintaining different folders for different Views (Design, Manufacturing, Service)...?
Well, what I have been told by PTC is that if one follows the above process of having stored different Views in different folders then it should give the opportunity to define ACLs based on Views.
Thank you
PRKAC
That's a good idea. If the OIR names the location for each view we could send users to a dead end if we don't want them to create a "legacy" view. We would have blasted them with training so this should not be a surprise.
It seems that the controls in place for default view is only for new part creation within Windchill and not via Creo check-in.
