MAPSB problems with Equivalence links
avolkanovska
We are using Windchill globally but we have quite some problems with MAPSB tool and so far all our sites are reluctant to use ScView
so i want to ask whether some of you have encountered similar issue or have different solution.
We use MAPSB to generate Downstream View, even when the first ScView is generated (from scratch) the system has the icons
which shows that either the equivalent part doesnt exist or that it does not have link. This (showing icons) happens in a random way, even though the  filters are set correctly on both sides (views) , also the structure is expanded before creation.
We have customized the tool and added few states so i dont know ifthat might be the issue for the straneg behaviour but anyhow is not helpful.
If anyone has ideas please reach out.. or if someone from PTC product management that can brainstorm on this that would be extremely helpful.
We have yet many sites to deply but if ScView are not used at all, the usage of the system will be far from the intendend one.
Looking forward to hear from someone
Many thanks
Aleksandra
0 REPLIES 0
