Hi Guys,
We have the option to create a multiple WT Part at a single time in Windchill, But I can't see the "New CAD Document" option to enable while creating the WT Part. Is there any possibility to do this?
AJ
Not without customization in the OOTB UI you described. There are other limitations of that interface. My users might create multiple parts but link up to them with CAD later via auto-associate when they check in the CAD from a workspace. If you feel strongly that this is needed, write up an Idea to submit.
Hello @Amirtharaj_K,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
