Maintenance: Restarting Servers
Darquise
Is there a recommendation as to how often the Windchill and database servers should be restarted?
Should they be restarted monthly? Is there an order as to which server should be restarted first?
6 REPLIES 6
ChrisSpartz
(To:Darquise)
There's no official recommendation from PTC about how often to restart the servers. Theoretically, they shouldn't ever need to be restarted, unless you make a configuration change that requires a restart. Though, in practice, that may not be the case.
As to the order of restarting, the DB needs to be available in order for Windchill to start up. So, the DB will need to be restarted first.
jessh
(To:ChrisSpartz)
LDAP should be up when Windchill is started as well.
Essentially the back-end datastores should be up first.
Thank you for your responses...
I find that approx every 25-30 days I get a "Memory usage threshold exceeded" notification and then Windchill slows right down and is unresponsive. so I restart the server, hence why I wanted to setup a monthly scheduled server restart.
How do you fix this error or clear memory usage without restarting the server?
jessh
(To:Darquise)
This suggests a slow memory leak. What type of memory threshold was exceeded? Heap or perm gen?
If the threshold was perm gen, then it is possible that the perm gen allocation should simply be increased -- and that it takes 25-30 days simply to make use of enough different features/capabilities to load that many classes. It may, however, be a slow leak, but this sort of issue is very hard to track down. One note in this regard, if using CMS garbage collection, be sure to use the necessary arguments to force this to include perm gen collection (which is unfortunately not the default with CMS garbage collection).
If this is not a perm gen issue, however, then it is most likely a slow memory leak. The only way to get a good idea as to the cause is to grab a heap dump and then analyze this -- or, more likely, have PTC analyze this.
Darquise
(To:jessh)
Here is the notification that I received:
Class:
class javax.management.Notification
Message:
Memory usage exceeds collection usage threshold
SequenceNumber:
11
Source (Direct):
  1. com.ptc:wt.subsystem=Monitors,wt.monitorType=Memory
Source (Original):
  1. java.lang:type=Memory
TimeStamp:
2014-05-08 19:30:06.340 +0000 [1399577406340]
Type:
  1. java.management.memory.collection.threshold.exceeded
UserData:
count
14
poolName
PS Old Gen
usage
committed
2859139072
init
2859139072
max
2859139072
used
2859139072
JVM Name:
3920@ACM
Threshold Info:
PermGenPercentCollUsage
  1. 84.45762062072754
PermGenPercentCollUsageThreshold
  1. 95.0
HeapPercentUsage
  1. 87.16486411932526
MinAvailableHeapPercThreshold
  1. 0.0
CheckIntervalSeconds
30
PermGenPercentUsagePeak
  1. 87.18524169921875
PermGenPercentUsage
  1. 84.46382713317871
MinAvailableHeapThreshold
0
PermGenPercentUsageThreshold
  1. 97.5
OldGenPercentUsage
  1. 100.0
GCBaitingEnabled
false
OldGenPercentCollUsageThreshold
  1. 95.0
OldGenPercentUsageThreshold
  1. 0.0
HeapPercentUsageThreshold
  1. 0.0
OldGenPercentUsagePeak
  1. 100.0
NoisyStillExceededNotifications
false
  1. 100.0
Memory Data:
Verbose
true
ObjectPendingFinalizationCount
0
NonHeapMemoryUsage
committed
404815872
init
195493888
max
469762048
used
404218584
HeapMemoryUsage
committed
3812163584
init
4288675840
max
3812163584
used
3322858904
Memory Pool Data:
  1. java.lang:type=MemoryPool,name=Code Cache
CollectionUsageThresholdSupported
false
UsageThresholdExceeded
true
PeakUsage
committed
50331648
init
2555904
max
50331648
used
49951616
Type
NON_HEAP
Usage
committed
50331648
init
2555904
max
50331648
used
49951616
UsageThresholdCount
0
Name
Code Cache
UsageThreshold
0
true
MemoryManagerNames
CodeCacheManager
CollectionUsage
Valid
true
java.lang:type=MemoryPool,name=PS Eden Space
true
CollectionUsageThresholdExceeded
true
CollectionUsageThresholdCount
0
PeakUsage
committed
1428094976
init
1072234496
max
1428094976
used
1428094976
Type
HEAP
Usage
committed
476512256
init
1072234496
max
476512256
used
464485688
Name
PS Eden Space
false
MemoryManagerNames
PS MarkSweep
PS Scavenge
CollectionUsage
committed
476512256
init
1072234496
max
476512256
used
458467824
Valid
true
0
java.lang:type=MemoryPool,name=PS Old Gen
true
true
14
true
PeakUsage
committed
2859139072
init
2859139072
max
2859139072
used
2859139072
Type
HEAP
Usage
committed
2859139072
init
2859139072
max
2859139072
used
2859139072
UsageThresholdCount
0
Name
PS Old Gen
UsageThreshold
0
true
MemoryManagerNames
PS MarkSweep
CollectionUsage
committed
2859139072
init
2859139072
max
2859139072
used
2859139072
Valid
true
2716182118
java.lang:type=MemoryPool,name=PS Perm Gen
true
false
0
false
PeakUsage
committed
369360896
init
192937984
max
419430400
used
365681408
Type
NON_HEAP
Usage
committed
354484224
init
192937984
max
419430400
used
354273576
UsageThresholdCount
0
Name
PS Perm Gen
UsageThreshold
408944640
true
MemoryManagerNames
PS MarkSweep
CollectionUsage
committed
354484224
init
192937984
max
419430400
used
354240936
Valid
true
398458880
java.lang:type=MemoryPool,name=PS Survivor Space
true
true
0
PeakUsage
committed
476512256
init
178651136
max
476512256
used
476491120
Type
HEAP
Usage
committed
476512256
init
178651136
max
476512256
used
0
Name
PS Survivor Space
false
MemoryManagerNames
PS MarkSweep
PS Scavenge
CollectionUsage
committed
476512256
init
178651136
max
476512256
used
0
Valid
true
0
jessh
(To:Darquise)
So with 100% of old generation used after garbage collection and 87.16% of overall heap being used, that's not looking particularly good. Was the system idle at the time? If so, then that's even worse.
As for what's filling all that memory, really only a heap dump can tell in detail. A heap histogram might give some clues, though.
