Does anyone else have a need to inactivate a large number of objects at once?
Current customized Windchill 9 functionality allows users to enter an object into a change task and execute an algorithm to determine what objects within the product structure of the initially added object are also eligible for inactivation. All eligible objects are then populated into the resulting objects section of the change task. Each resulting object has been revised, un-structured, and set to a state of review. Upon completion of the change notice the system sets the state of the resulting objects on the change task to inactive.
Looking for others with the same requirements or if someone has accomplished something similar with a more out of the box solution.
Thanks!
