Hello WC Gurus,
Here's a newbie question for you.
When I search for Users on the Participant Admistration page, my results are limited to 50 results/users. I would like to increase my results to 100 users -- which should sufficient to allow me to list all my users.
From the WC 10.0Basic Admin Guide (Ch.8, p.233), I see that the limit of the search result is controlled by a property named Max Count found in the wt.properties file. The default value is 50.
From Windchill 10.0 Specialized Admin Guide (Ch. 3, p.33), here iswhat I have been trying -- without success --in order to
[Note: The double-quotes are because my Intralink 10.0 is on a Windows SQL server and double-quotes are required per the WC 10.0 Specialized Admin Guide, Ch. 3, p.42, because of the space contained in the property name.]
Since xconfmanger did not find the Max Count property, I tried listing ALL the properties in the wt.properties file by using this command:
windchill properties wt.properties
But that result alsodid not list a property named Max Count.
And FYI,this is how I intend to
QUESTION: Can anybody tell me the exact command syntax for changing my search result limit from the default (50) to a custom value (100)?
Any enlightenment will be greatly appreciated.
Many thanks!
Scott
