May I get some help? I have a webject and am confused on the where clause syntax.
Linlin
6-Contributor
I use "Search-Objects". If get the name from the form input as Where condition. It works.
<ie:webject name="Search-Objects" type="OBJ">
<ie:param name="INSTANCE" data="localdomain.vm-windchill.Windchill"/>
<ie:param name="authorization" data="$(@SERVER[]AUTHORIZATION[0])"/>
<ie:param name="type" data="wt.epm.EPMDocument"/>
<ie:param name="where" data="(name='$(@FORM[]name[0])')"/>
<ie:param name="group_out" data="objectsSearched"/>
</ie:webject>
But if I define a String, then use it as the where condition .Like:
String whereKeyWord = "C6720PD.CATDRAWING";
Use the following syntax. The result is blank.
<ie:param name="WHERE" data="(name='<%=whereKeyWord%>')" />
Any help will be appreciated. Thank you so much!
Prabhash
(To:Linlin)
Hello Linlin,
I can not see any syntactical error in your webject.
I just ran the below webject and i am getting the o/p as expected:
<%@page language="java"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
<ie:webject name="Get-Properties" type="MGT">
<ie:param name="ATTRIBUTE" data="wt.federation.ie.VMName"/>
<ie:param name="GROUP_OUT" data="properties"/>
</ie:webject>
String wherecondition = "PK_NS2";
<ie:param name="INSTANCE" data="$(properties[0]wt.federation.ie.VMName[0])"/>
<ie:param name="type" data="wt.part.WTPart"/>
<ie:param name="WHERE" data="(name='<%=wherecondition%>')"/ >
<ie:param name="attribute" data="number,name,version,lifeCycleState" delim=","/>
</ie:webject>
When you get the name from form input, is it the same EPMDocument "C6720PD.CATDRAWING"?
LoriSood
22-Sapphire III
(To:Prabhash)
Is the name case-sensitive? Using the above example from Prabash does it work for you?
Linlin
6-Contributor
(To:LoriSood)
Thanks to all of you for your help. It doesn't work for me either. I changed my code to get all values without where conditions , then use javascript to filter what I need. Thank you so much!
JuhaA
(To:Linlin)
Instead of Search-Objects you could use Query-Objects it works!
<?xml version="1.0" standalone="yes"?>
<%@page language="java" access="http|soap" contentType="application/xml"%>
</ie:webject>
<ie:webject name="Query-Objects" type="OBJ">
    <ie:param name="INSTANCE" data="${properties[0]wt.federation.ie.VMName[0]}"/>
    <ie:param name="WHERE" data="name=${@FORM[]name[0]}" />
    <ie:param name="TYPE" data="wt.epm.EPMDocument" />
    <ie:param name="ATTRIBUTE" data="name" />
    <ie:param name="GROUP_OUT" data="out"/>
</ie:webject>
