Merge Option Sets
EC_10581209
Merge Option Sets
Hi community,
i have two Products Prod A and Prod B. Prod A is the Parent so it will be the TopLevelOptionSet Product B is the subassembly and is the LowLevelOptionSet. I`ve tried the https://support.ptc.com/help/windchill/r13.1.0.0/en/index.html#page/Windchill_Help_Center/options/OptionsMergeChoicesRules.html# and this https://www.ptc.com/en/support/article/CS367055
I used the shell command: xconfmanager –s ato.optionset.merge.delegate=com.ptc.windchill.option.service.DefaultOptionSetMergeDelegate -t "codebase/wt.properties" -p
which should enable in the detail tab when i go to Actions and Merge Option sets but it is not available for me, have i done something wrong?
1.
on the site.xconf it looks like this
2.
even it is on the site.xconf available i cannot see it in the Action menu
3.
4. how it should look
5 REPLIES 5
Hi @EC_10581209
Thank you for your question!
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
The "merge option set" is only available for a user who is e member of the group "Platform Structures" (I think this is a licensing group).
Can you please check this and revert.
Cheers
Hari
is it possible with wcadmin licence?
Regards
Yes, It should work with wcadmin. Usually there is no restriction with wcadmin in terms of menu options / licensing.
Hi @EC_10581209,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC
