What is a good method server to CAD user ratio? Right now I have 5 heavy users, soon to be 7, and 2 light users all on 2 method servers and 1 background method server. The Windchill check in, check out, and save & upload times are terrible. 7 to 10 minutes or more terrible! Everything runs okay with 2 heavy users on but when you add the 3rd, 4th and 5th you can actually see the impact of each additional heavy user. Do to the type of work that we do here, each of our heavy users are checking in and out several times an hour. Windchill 8.0 040 Dell PowerEdge 2950 Dual QUAD core XEON 2.00GHZ CPUs (Quad Core Xeon Processor E53352x4MB Cache, 2.0GHz, 1333MHz FSB) Note: CPUs mostly running idle. 4GB of RAM (4GB 533MHz (4x1GB), Dual Ranked DIMMs Windows Server 2003 R2 Standard Edition: will have to upgrade to increase RAM Should I upgrade the O.S. and add more RAM and create 1 method server for each heavy CAD user? Could there be another issue here? Any thoughts? I don't want to just throw more RAM at the problem. I want to know the real cause and solution. Doug P.
