Microsoft Edge & Windchill 12
TRun222
I have no problem logging into my acct thru IE or Firefox browser, microsoft edge however launches me to the "Login Authorization Failed" without even having the pop for login appear.  As I type it out, its probably an issue with my companies allow list for pop ups, but out of curiosity is there a setting in Windchill that allows the use of login with Edge, or should it work by default and I need to contact my companies IT so I can use Edge?
If this is unrelated to PTC/Windchill, I'll just delete this topic,  Thanks!
Cassie
(To:TRun222)
Please check if you are using supported version of Microsoft Edge. https://www.ptc.com/en/support/article/cs196783
And here is Temporary solution:
Hi, have you found any solution? We have a similar case.
avillanueva
22-Sapphire I
(To:TRun222)
