Version: Windchill 13.0
Use Case: Currently i using windchill 13.1.2.0 version Based on creo view adapter 12.1.0 Microsoft Office 2019 , 2021 , 2022 ,2024 and 365 is it supported OS version 2019 and 2022 ?
Description:
Hi @SM_14152020
PTC Advisor should answer you question
CS196783 - Software Matrices of Windchill PLM
Release Advisor - Windchill PLM 13.1.2.0 Release Matrix
So if the Office 2019 and 2022 are supported by Microsoft, then both versions should work.
PetrH
Hi @SM_14152020,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
Hi @SM_14152020
PetrH
